I'm at the point where I am slowly replacing my line. I have quickly learned that rope is surprisingly expensive.
My next task is the jib line. I've been told that the newer lines (especially those with dyneema) are so strong that you can use slightly smaller diameter line. I'm at the point of replacing my jib lines. Are lines on cats a standard diameter or does each boat differ based upon the manufacturer's design?
The class specs for my Dart say "09 min", if I'm reading it correctly. That can't be a minimum of 9 mm, so I'm not sure what that measurement means.
Short of taking the line off the boat, how can be assured I'm buying the correct line?
Dana
Dana, Holly, Emma & Hannah
LJ/Stu's Dart 18 (Sold! :( )
