I also use the trapeze lines to stabilize the mast while raising/lowering. For some reason my front beam has some flip-flop block on it and I use them, a carabiner and a section of rope to attach the trap lines. I also created a rear, removable, mast stand that is attached to the trailer. The stand sits several feet higher than the tramp and I can slid the mast rearward on the stand to get the mast onto the ball. Then I simply raise it with the winch. The extended mast stand in the rear gives me an angle advantage and this aids in the initial raising of the mast. This works so well that I dont need a gin pole. I can raise the mast in 5 minutes or less. Here is a video of the mast going down:
https://www.youtube.com/watch?v=J95E0Vmjk6s. The rope in my right hand is used to rotate the mast 90* as it's being lowered. Next time I go out I should make a mast raising video.
Edited by tradisrad on Jun 11, 2018 - 07:49 AM.
