Hello,
We’ve been sailing a 570 for 4 years and lately the Halyard Ring does not set into the Mast hook easily. Instead it rests on the tip of the hook. We have to confirm that it is set with binoculars. We are currently using a Hobie Aussie Halyard ring with a welded shackle. Prior to this we used the ring that NACRA supplied but the metal is thicker and diameter of the ring narrower so we thought the Hobie ring would be easier but it is not. We like the welded shackle because it makes it easier to pop off the hook. We tie an 8 knot facing aft and are considering having the knot face the mast slot. But, our hook is in the center of the mast and we are concerned it will not come off the hook easily if the knot is up against the pulley.
Does anyone have a solution for us?
Thx much.
