I should be up there then, but i am hoping to figure something out sooner. My kids have moved on and I have regular crew so I'm trying to make this easier to solo sail. I have never had to do get the mast up solo before. I built a Mast stand to put out behind the boat to support it but I'm doubtful I can just lift it up and even then be able to get the forestay attached. Are you in the Salt lake Valley somewhere I might could swing by and take a look sometime. Did you build your own? Right now I'm struggling with figuring out the best way to attach it to the mast.
Thinking of trailer with the cat backwards and using the front mast stand to get a jump up but I'm not sure it will work well with the spreader wires and sideways mast raising of the P18. Plus then I will have to built or buy a rear mast holder for the trailer because I will not be able to rest in on the rear beam. I might could reconfigure the trailer so the rear is higher thus leaning the mast forward to help keep it in place while i get it attached but that would take a bit of work.
I have a section of fiberglass windsurfer pole that was originally designed as a righting pole system I though I could use as a gin pole but it s a bit long so I thought I may need to cut it down some.
Member:
Utah Sailing Association
Check out "
Prindle Sailors" on Facebook.
