Epoxies, Vinylesters and Polyesters Explained - MAS Epoxies
Epoxies represent some of the most versatile resins available to the composite manufacturer. Generally, in all categories of work, the builder/repairer will realize the greatest degree of bond strength, waterproofing and toughness with well formulated epoxies.
Vinylesters
Vinylesters represent a resin development step in the right direction. While still utilizing a polyester resin type of cross-linking (i.e. peroxide cured). These hybrid resins are toughened with epoxy molecules within the backbone. Shrinkage is less of a concern with vinylesters and prerelease of the part from the mold is reduced. The toughening effect of the resin modifications makes for a better resistance to micro fracturing and some of the secondary functionality of the backbone assists in adhesion to substrates. Vinylesters are capable of forming secondary bonds around 500 PSI (MAS Epoxies 2000 PSI). Resistance of vinylester resin to moisture is good and some commercial barrier coatings have been marketed utilizing this resin family. The down side of the vinylesters include sensitivity to mixing, handling, atmospheric moisture and temperature sensitivity (sometimes it just will not cure).
Polyesters are one of the least expensive resins available to the FRP boat builder utilizing female tooling in the form of a mold. Polyester has the advantage of being extremely inexpensive when compared with other thermoset resins i.e. vinylesters and epoxies. If the upside is cheap pricing, the down side includes poor adhesions, high water absorption, and high shrinkage. Polyester resins are only compatible with fiberglass fibers.
https://www.jamestowndist…al/document.do?docId=495
