I recently bought a 1980 Prindle 16. First boat of any type that I have owned. Took it out immediately, and I loved it. I am hooked.
It's completely sailable, but it's a bit old and neglected, so I am going to be restoring it over the winter. I've already replaced the easy stuff, and now am into the rudder. From what I've read, the rudder seems to be the weak link on the Prindles The first thing I did was tear out everything and order replacement sheaves and lines. The rudders themselves have been patched up, sanded, and I'll soon by putting a nice shiny gel coat on them. The castings were in, well... not great shape. The castings were rather wide and bent. They were about 3/4" wider at the outside than the inside. I have since remedied this issue on the castings, sand blasted them, and powder coated them.
So here is the issue:
Years of these castings being out of spec has allowed the hole in the rudder that it pivots on to wear out. It's rather enlarged, and makes the rudder sloppy, and makes the release even more sensitive and hard to adjust correctly.
The plan:
I plan on drilling out the hole and pushing it back to 1/4" before I gel coat these things
The question:
What is inside the fiberglass of the rudders? I don't want to drill out the hole and sleeve it if there is nothing substantial behind the fiberglass I'll be removing, or at least, I'll need to think about it a bit more and possibly put a fanged bushing in there to distribute the load.
Thanks!
Brian
EDIT: I guess worst case I could just make some new, wooden rudders.
Edited by briantroberts on Aug 26, 2018 - 04:47 PM.
