If you run the halyard along the jib, you will want to remove the line in excess, as in the video above. If you run it along the mast, it's not a big deal, because you will likely store it on the tramp pocket anyway (you don't want to leave it on the beach, just in case). What I do for the 2:1 downhaul is as follows:
- One end is tied to an eyestrap somewhere on the side of the mast, say about 20 cm or so above the base
- Then thread it through a small block and to a cleat on the mast, not far from the eyestrap. Cleat pointing down.
- The small block has a fast shackle, which is attached to a loop knot on the halyard, after the jib is hoisted. The loop is at a position that allows for adjustment. It will limit how far down the other end of the halyard will go, so you will need do figure out the right spot.
Something like this (the picture of the right.. not my boat, found it on google):
Edited by Andinista on Sep 04, 2018 - 08:48 AM.
