Furler and swivel
A while back I got a furler and swivel off eBay (from a member of this forum).
It is the Harken 434 kit. After looking through the Harken catalog I saw that the 434 is a low-load application (500lbs) and the 435 is the standard application (950 lbs).
It’s my understanding that this furler was used on a SC 20 by the previous owner and I’ve got it on a Nacra5.7.
I have no idea of the loads on a forestay and I’m sure these things are over-built, but I thought I’d ask the advice and opinions of folks with much more collective knowledge than my own.
Collierville (Memphis), TN
Supercat 15--sold :(
Hobie monocat--given
Vanguard 15--traded for...
Nacra 4.5--sold
Supercat 17–sold
if your worried, just upgrade the bearings to the Torlon ones that's the only difference
MN3, thanks pal, I didn’t know the internals of these things but suspected that might be the difference. I’m not really concerned about function because they are running perfectly smoothly. But is the design such that the different bearings could cause a structural failure? If that’s the case I’ll look into new bearings over the winter, otherwise I’ll change them based on wear.
Nacra 4.5--sold
Supercat 17–sold
I'd really like to get a roller furler for my 5.7. You would think I'd have done this before waiting 34 years! I'll have to put up an ad on parts wanted.
Tnell, did you ever do the decals?
https://i.imgur.com/MFWO3Qq.jpg
The boat has been painted ice blue. I’m going to lay the decals out and see how they look with the new paint.
If you need any suggestions on the furler setup let me know.
Nacra 4.5--sold
Supercat 17–sold
Tim, I was exactly in your situation years ago. One of th first things I did was put roller curling on my 5.7.
I simply bought 100 Torlon bearings & swapped out the old ones. ( Still have the old white ones, if anyone wants them for a Lo Load system PM me).
I docum ented the rebuild procedure, here is everything you need to know.
https://www.thebeachcats.…67de927877ba25f8f58006f7
Edited by Edchris177 on Sep 24, 2018 - 07:00 AM.
That is so perfectly what I needed to know...that’s what this community is all about.
Thanks guys, and thanks To Damon too for creating this place. Also thanks to Damon for telling me how I can beat him next time!!
Nacra 4.5--sold
Supercat 17–sold
Ed,
Can you recall where you got the torlon balls? I’m having trouble finding that size. I found them for 45 cents but maybe can get them cheaper
Nacra 4.5--sold
Supercat 17–sold
sailing services in miami sold me mine
305 758 1074
http://www.sailingservices.com/
Thanks again! They have generic and Harken. The Harken are .02 more per ball but still only .22 per.
Since that’s half the price I found elsewhere I doubled my order so I have another set on hand.
The lady on the phone was probably the best phone sales person I’ve ever spoken to. VERY helpful and friendly, and she had a guy helping her in the background to make sure we got it all correct.
In one quick call I can highly recommend this place for good phone skills at least.
Nacra 4.5--sold
Supercat 17–sold
glad to help
make sure you count how many come out and use the correct amount
i destroyed a furler by using too few.
i would also suggest you work on a Frisbee or similar as bearing go everywhere
Edited by MN3 on Sep 24, 2018 - 10:37 AM.
Murrays has the whole kit ready to go... I have used this on a few application (NACRA 5.8 being one of them) and I believe this is the same hardware that was used on the NACRA 20.
https://www.murrays.com/product/30-5051/
As recalled, I need to shorten my forstay a little compensate for the extra hardware...
John Schwartz
Ventura, CA
The swivel and drum are each 2-1/2” pin to pin, and the upper pig tail I used was 6” ( I think it was a Hobie stock item) so my new forestay was 11” shorter than the original. I sourced the expensive parts used (drum and swivel) and had murrays build the rest of my new rig to fit. I probably saved close to $200 going this way but I do have used parts and need to replace $25 worth of bearings.
Nacra 4.5--sold
Supercat 17–sold
QuoteThe lady on the phone was probably the best phone sales person I’ve ever spoken to. VERY helpful and friendly, and she had a guy helping her in the background to make sure we got it all correct.
I’m pretty sure I also used Sailing Services. The person I talked to sounded Cuban, very helpful, wish there were more like it...(West Marine, are you listening?)
Unless you fill the drum with sand on a regular basis, you won’t need to change them for a long time.
MN3i would also suggest you work on a Frisbee or similar as bearing go everywhereEdited by MN3 on Sep 24, 2018 - 10:37 AM.
Even better is a light coloured towel. You can see everything, & nothing bounces or runs away when dropped.
Edited by Edchris177 on Sep 25, 2018 - 07:11 AM.
Alright, I now have 200 5/32 (aka 4 mm) torlon balls on hand. I will replace the balls in the Nacra and have a spare set if I need them for the Supercat.
Funny thing, the difference in the 434 and 435 furler sets is about $80, but the difference in the bearings is only $20-25.
Nacra 4.5--sold
Supercat 17–sold
Thanks to Edchris177, MN3, and Sailing Services.
I have nothing to add to the good write up and photos from Edchriss177.
I did have just a bit of trouble removing the barrel from the drum just because it was a little stuck from old grease. A light tap on the end of a very fine flat blade screwdriver took care of it.
It turns out my swivel already had the torlon balls but the drum did indeed have the delrin ones.
Anyway, I was able to get a thorough inspection and cleaning of everything and changed all the balls. The swivel looked like it came off the shelf at Murrays or APS yesterday. The drum had just a bit of old grease with no signs of salt crust or corrosion anywhere.
Next up a trick (or at least tricker than stock) downhaul on the SC and some special secret jib sheeting enhancements for my Nacra crew. (Starts with ox....ends with ...cks).
Nacra 4.5--sold
Supercat 17–sold
