What are the recommended bits and pieces for conversion of a nacra 5.2 to roller furling jib to facilitate single handing? Murrays has a kit for about $500 but I would like to keep the cost down as much as possible while not risking dropping the mast due to under strength elements.
I have considered a DIY unit but the ones I have found do not seem robust enough for the strain of the forestay. A working load of about 1000lb seems about right. I have modded a hub from a garden cart but the bearings are ok for radial load but I doubt they will hold for axial load of 1000lb.
SeldenFurlex 60?
RWO swivel?
Ronstan Series 60?
It looks like I can fold over the top of the forestay in a new eye to shorten it compensating for the height of the drum and swivel and leaving a pigtail for the jib halyard block. Would need a cleat just above the drum.
Any clues, guidance, pictures etc. along with brand and model numbers for hardware would be welcome.
