Is this something that happens generally to catamarans in high winds? Or to certain models in high winds?
I'm basically trying to figure out whether I have to expect/accept this in high winds w/ my boat, or is there something else I have to do.
Background: So before I bought my boat (P18.2) I watched a video of a prior owner sailing in high winds and at one point they made a couple of unsuccessful attempts to tack but got stuck in irons. The narrative posted in the video said "too windy to tack - so we jibe." (No need to watch it, but it's at 2:40 here: https://www.youtube.com/watch?v=SlEbMYx3YI0.)
I figured well, they must have been doing it wrong. The owner's manual says don't just throw the tiller over or you'll stop the boat's momentum; move it gradually so the boat sails through a U-shaped arc & keeps moving. Ease out on the main a little and let the jib back wind until you're definitely through. Also don't try to come about from a broad reach - be sure you start sailing closer to the wind.
So yesterday in high winds and decent-sized waves sailing solo to my surprise I ran into the same problem multiple times. Tried to come about and got stuck in irons. Backed off and tried it again from varying speeds and angles - more off the wind to start from a higher speed, then closer to the wind to have less of a turn to make. Made best efforts swing through at just the right speed to keep moving, and still no luck. Just seemed like the winds were so strong they would not allow the nose of the boat to make it through the wind. Was finally forced to jibe on multiple occasions (which really sucked considering I was trying to beat an upwind course).
When I crewed on the I-20 (actually when handling the helm a few times) I was impressed by how effortlessly it came about through the wind - just seemed to pivot on a dime no problem. I attributed the difference to the fact that (a) the I-20 hulls are rounded on the bottom, whereas mine are more V-shaped, and (b) the I-20 has long thin dagger boards - compared to the wide, sort of half moon-shaped pivoting boards on my boat (P19 same).
Any comments, esp by P18.2/P19 owners, on whether I have to expect this in high winds, or is there something else I can/need to do when the winds are really honking to make it through? (Medium winds are no problem.) Also, for anybody, is this a thing that happens with other models of cats in high winds? Thanks.
Edited by CatFan57 on Oct 29, 2018 - 10:23 AM.
1998 P18.2
Sailing out of SHBCC, NJ
