Viking inspection port o-ring measures
Hi, I need to replace the o-rings of 4" Viking Marine inspection ports, they are out of stock at Murrays and didn't find them elsewhere. Anybody has measured the o-ring diameter and section, to find an alternative? I'm away from my boat, Thanks
Did you try Annapolis Performance Sailing
John Schwartz
Ventura, CA
Or how about going directly to the source....
http://www.vikingmfg.com/contactus.html
DogboyOr how about going directly to the source....
I read they dont make them anymore (and i believe what i read on the internet...)
Found some here, in Switzerland, and ordered the 6 units they had in stock.
https://www.h2o-sensations.com
I live in Chile, so not too different than ordering from the U.S.
Interesting site, i got some other stuff too
Edited by Andinista on Dec 04, 2018 - 03:55 PM.
Go to McMaster Carr, buy some linear o-ring stock, cut and glue the ends together. Very easy and no need to chase down a Viking specific o-ring.
dk
Blade F-16
Hobie 14
Corsair F-242
Mirage 25 (Sold)
Hobie Tiger (Sold)
Hobie Tiger (Sold)
TomCat 6.2 (Sold)
dssaakGo to McMaster Carr, buy some linear o-ring stock, cut and glue the ends together. Very easy and no need to chase down a Viking specific o-ring.
I was going to recommend Granger of The O-Ring Store.... but I saw that APS had them.. all you need are the measurements...
https://www.theoringstore.com/images/oring_id.png
John Schwartz
Ventura, CA
Here is what I use. I purchase them at a local industrial supply house, buna, and replace them every year. As a tip, when you're not sailing, loosen them a bit so that they're not compressed all the time and loose memory/seal. Also inspect and clean them periodically, sand/dirt etc. doesn't make fot a good seal:
https://www.bestpartsonli…/product&product_id=5143
Edited by leeboweffect on Dec 12, 2018 - 01:22 PM.
One of the die makers at Viking had a bit of fun one afternoon...
https://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=130627&g2_serialNumber=3
