Posted: Mar 01, 2019 - 04:34 PM
I have an I20. Here are a few pros and cons from my experience, especially related to the spinnaker conversation we are having...
Pros:
The boat is so well balanced under spin. I have gen 2 rudders. You can be flying along at a 45 degree heel angle and they always have enough bite to easily (fingertip) bear away and depower. I never worry about not being able to sail deeper in order to depower. It's amazing. One of my favorite things about the boat. It was designed around the spin.
In 7 knots of wind you can solo sail the boat under spin at a steady 15 knots, no problem. I've sailed 16 knots solo with the spin up, but not faster because I worry about taking the spin down alone in more wind. The thought of having to crawl to the front of the boat to untangle something on the spin pole in 10 knots of wind is just frightening (boat turns up and goes over)... One of these days I will try to solo with the spin in 12 knots and get back to you if I survive. Soloing with the spin in 7 knots of wind is like a magic carpet ride though. Hell, it's fun in 4 knots, where you are flying a hull and passing all the motoring monohulls. Upwind solo in 7 knots, is every bit as fast as floating A-Cat. You can do 12 knots. Soloing quickly stops being fun in winds above 7 knots or so...
The big question.... I can right it solo, with water bag. I weigh 225 lbs. I still worry about not always being able to do it before drifting into something. May carry a small anchor this season, if I solo at all. You have to get back on quickly to as the boat may want to take off with you hanging onto the side.
The trampoline layout is clean, you have all the space the world. Good organization.
Cons:
It's obviously really a two person boat...
Soloing quickly stops being fun once the wind starts to exceed 7 knots. You just cannot sheet in properly and keep the boat from going over. Maybe if you travel out and depower other settings to the max, you could get a wild ride in more wind. However, you generally need a crew member in winds over 7 knots to make the boat go faster than 15 knots.
To get the boat to go above 18-20 knots with, you have to be good at depowering. Otherwise, she wants to go over rather than forward, even with two gorillas on the wire. If you get the downhaul, boards, mast rotation, and traveler settings right, you can sheet in and shoot forward rather than go over. The boat can start to feel overpowered in as little as 12 knots with two on board if you don't start depowering.
Edited by traphappy on Mar 01, 2019 - 05:50 PM.
