My Gcat 5.7 has a stainless ring that runs between the 2 bridles and the chainplate for the forestay. I assume I can ditch it for a shackle? Any reason to keep the ring? Seems like a hassle to cut the ring, put on new bridles and then find a stainless welder to tack it back, but if that’s the better configuration I’ll do it
Seems like if you just use the biggest bow shackle you can find that will still fit through the bridle thimbles, you should be fine. Lot’s of boats use a shackle.
probably fine to use a shackle but the downside may be:
well a "jesus" shackle will probably weigh more than a ring and i know i couldn't get the shackle on my mast tang through my bridal eyes
a shackle can come un-done with enough bouncing and movement (i have had side stays with shackles come undone if they weren't secured with a plier or had a safety wire attached through a hole in the pin)
a shackle will deform with enough force (so will a ring)
and a shackle can rotate around (if the rigging is a little loose and the main is released) and might cause one bridal to be different to the others
