Last week, while sailing my P18 on a lake outside of Orlando, I was hit broadside by a jet ski going at least 30 kn. The impact was along the seam where top and sides meet, about a foot from the front of the starboard bow. The guy who hit me was hurt but still got back on the jet ski minutes later and fled the scene. Craziest thing.
The top of the hull has a 30" crack and the seam where the top and the side connect is separated cleanly.
That separation is about 40" and is extends further aft from where the crack is. I just cut out the damaged area on the top to assess interior damage and begin the repair process.
The inside revealed delamination damaged (caused by the impact) that extends laterally from the crack - the widest are being about 5". Here are some pictures of the delaminated material that's been cut.
I successfully repaired (fiberglass and gelcoat) side hull damage (major holes) a few years ago and feel confident about repairing the hole i've cut out but I am not sure about how to ensure a good repair on the separation between the side and top of hull. I assume use a lot of resin and inject from inside and outside then clamp and strap down. Will that work?
Also - how can i achieve the grid texture on the top of the hull?
Thanks in advance for advice. Will document process and share.
Mike
