Cartopping hulls
Occasionally the need to car top a hull or two arises. A hitch mounted canoe carrier is great for aft support but too narrow for two hulls. Solution, unbolt 16 or 18 inch top cross bar and swap in a piece of unistrut. Bolt tight and voila, another anchor point. This is on a Caravan btw.
No elegant front anchor system discovered yet. Just way too much plastic to deal with.
Can you install a front hitch receiver?
'82 Super Cat 15
Hull #315
For front anchor, raise the hood and tie a loop of rope around hood hinge. Now you have anchor points forward for a rope. Pete
best be careful and check your local laws
there are federal and state laws that restrict the amount of overhang you have
I have moved hulls before - i took the cat off my trailer and used it ti move hulls
same with a mast
https://content.sailinganarchy.com/uploads/2019/03/floriduh.jpeg
