I picked up a 1983 Prindle 18 a couple winters ago for $250 that had some issues that needed to be addressed (soft spots from trailering, missing turnbuckles) but after last summer and this spring I think I've got it in sailing condition again. It was missing some pieces when I bought it so the owner couldn't demonstrate setting it up. I've been sailing little sloop-rigged boats for quite a while in our local lake but decided I wanted to try something a little more exciting.
a couple weeks ago I got the mast up and everything ready to go but I couldn't figure out how to properly set up the main sheet and block. If anyone has a handy youtube video of how it should be set up or even can find couple pictures of how the boom, cleat, and traveller are hooked up i'd be appreciative.
Second problem i'm having, the mainsail is impossible to raise completely while the mast is up, it gets stuck about 5 feet from the top. with the mast off the boat and laying on the ground I can get the sail all the way up if I have a friend guide it. I've cleaned the channel on the mast with some soap and then alchohol and was thinking about using some sort of lubricant in the channel but i'm not sure what sort wouldn't damage the sail. If anyone has input on that particular issue I'm definitely open to ideas.
Thanks!
