Posted: May 29, 2019 - 07:53 AM
I believe even if you run it on electric, they still need to be level (within about 2 degrees of plumb). Its an absorption fridge, so instead of a flame heating the ammonia, its an electric coil is the only difference.
I would go with an ice box (Cooler). I believe the key to it is to keep the melted water away from the ice as water has much better convective heat transfer properties than air. (i.e. melted water will make the remaining ice melt faster. Note, I have not done any research on this, it just makes sense in my mind)
Conversely, you could just switch to shelf stable goods and rum.
Edited by badfish on May 29, 2019 - 07:55 AM.
Joshua
Texas Gulf Coast
'82 Prindle 16 (Badfish)
‘87 Hobie 18 (Sold)
