I noticed a EZ Stepper 3 with stuff sitting around. From what I read, you either pull on a trap wire, which pulls the front of the mast, sort of upsetting the side stabilizing wires, or pull on a slug in the mast sail track, which twists the mast the other way when winching begins.
I only lifted 5 feet, as I set up under a tree, but the change inside tension makes me worry.
The gin pole and side anchors are done via a strap, but that moves a bit too. That may be a cause too.
I would welcome any hints on raising masts sideways solo.
