Posted: Jul 11, 2019 - 07:09 AM
There is no lube called for or required.
The sleeves do get stiffer, & brittle with age, however they are useable until the little ears, (where the pivot pin goes through) break.
There are two slightly different types. They work the same, but one has aluminum cleats, the other plastic. The plastic cleats teeth get worn & allow the line to slip. I have drilled out the 2 rivets & replaced the cleat with a small clam cleat. As with any cleat there should be no slippage. It sounds like yours are worn out.
It is also hard important to use proper line. You must use very low stretch line, else the stretch allows the rudders to move slightly upwards, resulting in helm pressure at the tiller.
Thinner line, (IIRC 3/16” is OEM spec) goes deeper into the cleat.
Edited by Edchris177 on Jul 11, 2019 - 07:12 AM.
