I'd like to adopt Sam's idea (run downhaul line back), but preserve the line that I have (currently cut and joined with sister clip) if I can splice it back together. The APS specs say the line (FSE Robline 8-plait Dinghy Line 5-mm) cannot be spliced. However, it looks like it could be spliced end to end by removing some core and splicing the cover. I have a D-splicer that I've been waiting to learn to use. Could this work, and then could I use this line with a Spinlock PXR swivel cleat? Perhaps the big consideration (???) of using it with the cleat is that the core is not dyneema, but rather polyester. The cover is also not very loose. As a side note, this line slipped on me in a 150 cam cleat when used as a spin tack line. Thanks. It would be cool if I could learn to splice and save $100 as I try to improve my downhaul setup.
Edited by traphappy on Jul 23, 2019 - 08:08 PM.
