I bought an '81 H16 and I have some questions about previous repairs done on the hulls.
Imgur Album
The right hull looks mostly fine so all the pictures are of the left hull. I'm mainly concerned with the large repair and crack near the rear (pictures 1-4). Pictures 5&6 show a small hole drilled into the top center of the hull roughly half way between the front pylon and the front tip of the hull. The right hull has a matching hole. What are these for? Is the brown material surrounding the mesh just the unpainted hull or is it resin/epoxy/etc? The hulls don't have any soft spots, even around the pylons, but there are some thin spiderweb cracks in a few areas.
I've been sailing H16s every summer for a decade but I've never owned one so I don't know anything about the repair work. I've made custom fiberglass speaker pods for my car and I'm pretty handy so I'd appreciate any advice on what needs to be done to get this boat in the water.
Let me know if you want any additional pictures or different angles. My wife and I did a test run of stepping the mast and raising the sails and I've checked all the stays, lines, cleats, the rudder assembly, the tramp, hull plugs, and the mast so I'm hoping to sail her for the first time this weekend!
Edit: Individual images linked below:
Edited by temuchan on Aug 22, 2019 - 02:56 PM.
