The cat box on the trailer holds the rudders (assembled), boom with main sheet blocks attached, sails (rolled in a sail bag), PFDs, and harnesses. The last two are in web mesh bags to help dry. Everything gets pulled out and rinsed when we get home.
Spare tire is bolted and locked to the tongue horizontally, with a plywood and Sunbrella cover to act as a step up front.
Hydraulic jack, tubes of lube and repair goo, and other tools are kept in a plastic trailering tool box in the garage, and put in the vehicle when trailering.
Stainless steel fittings, gloves, misc. personal gear, and extra line/blocks are in a duffel that has a tag on the outside to remind me to bring the radios, flares and first aid gear stored elsewhere. Inside the duffel is also a small zippered pouch that contains duplicates of the shackles, hinge pins and small vise grips needed to rig the boat, that could fall into the water and be lost. (Might have happened once...
Does this help?
