Sail Box
I am working on an inter 20 and need a longer sailbox for the spinnaker pole. The spinnaker pole with snuffer is too long to fit in the box. The box is made of 3 fiberglass sections (see photos below). I recall this type of box was very popular years ago. Does anyone know who made the box and if I can buy sections? I would rather not have to splash a mold to make parts if I can find reasonable parts or an old box to scavenge.
https://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=132572&g2_serialNumber=3
https://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=132579&g2_serialNumber=4
Thank You
David
Inter 20
Southern Maine
The short answer is probably not...the cheapest solution is to cut a hole and cap it with PVC.
The next option is to buy a new 12' box for $2k+.
Get hold of Kenny B. He’s probably the expert in this area
Collierville (Memphis), TN
Supercat 15--sold :(
Hobie monocat--given
Vanguard 15--traded for...
Nacra 4.5--sold
Supercat 17–sold
I have never seen a fiberglass box that came with a spin pole setup
as mentioned you will prob need to fabricate a solution
or purchase something custom
Looks like the trailer already has a PVC tube mounted to it, presumably for holding the spin pole. Seems like you already have a solution for carrying the pole.
Box looks big enough for the spin pole. My pole is a two piece, remove the hoop, pull it apart, shorter than the boom. My trailer has a 12" PVC tube on it. I can measure it if you would like.
Steve
Nacra Inter 20
Okemos Michigan
QuoteLooks like the trailer already has a PVC tube mounted to it, presumably for holding the spin pole. Seems like you already have a solution for carrying the pole.
spin poles have hoops and snuffer bags attached -
i would assume most hoops are riveted to the pole like both mine are (no one wants bolt ends or nuts near their spin hoop where the spin can snag and rip)
most poles i have seen are single piece alum or cf - so taking it apart for storage is not an option
Edited by MN3 on Feb 24, 2020 - 01:56 PM.
To elaborate on what Sam said, I've seen people just make an extension for the box by getting a PVC flange, bolting it to the box, add a piece of tube with cap on the end for the end of the pole to fit in.
http://www.sailboxes.com/
Talk to Kenny, he has the molds for that box.
Spin poles come in many flavors. I've been carrying mine outside the box for a while now, but you need a good cover for the bag or will have issues. Nacra build their new poles with Rivnuts so 2-3 screws is all it takes to strip the hoop, then its actually much easier to transport in a box or outside.
Thanks guys. I'm converting to a midpole SNU like setup and plan to leave the hoop and chute in the snuffer on the pole for quick rigging. I have a 1 piece carbon 14' pole from my 6.0 and do not want to cut it down or make it 2 pieces. I will talk with Kenny. Stretching the box will also allow me to fit all of the gear including harnesses, wetsuits, etc.
Cheers,
David
Inter 20
Southern Maine
I modified my spin pole (stock midpole snuffer) to break down in two pieces, to fit in the box. Works well, and I have used the same pole for years. No tools or fasteners involved, just slips together.
Edited by P.M. on Feb 25, 2020 - 10:38 AM.
The F18 that I am sailing has a 6" diameter PVC pipe protruding forward out of the sailbox. I think this would be a lot cheaper than a new sailbox. It works great except we have a new spi pole that is 8" longer that the old pole. Now we need to lengthen the PVC pipe...
Flightlead Bimare F18 HT SpaceCoast
Thanks Ron...David contacted me and we're working on a solution. BTW... I have a mold for spin pole extensions if anyone wants one.
Kenny Boudreaux
2010 C2 F18 USA 323
Owner of Sailboxes.com
Video on facebook for sailbox.
https://m.facebook.com/gr…link&id=1273559836170078
Steve
Nacra Inter 20
Okemos Michigan
Sam;
Do you transport with the spin pole attached to the front beam? How is the front supported?
samc99usSpin poles come in many flavors. I've been carrying mine outside the box for a while now, but you need a good cover for the bag or will have issues. Nacra build their new poles with Rivnuts so 2-3 screws is all it takes to strip the hoop, then its actually much easier to transport in a box or outside.
Brett
2012 Goodall C2 with 2014 Hulls (warranty)
1992 Hobie 18 w/ SX Wings (Sold)
Tucson, AZ
I've been using the same large PVC tube for a sail box for over 35 years. It's on a galvanized trailer that I've exchanged trailers with boats I've purchased over the years. What I like about it is that you can easily use it solo, opening one end and sliding stuff out. And if you replace the cutting boards with thick Teflon panels like I did recently, it can be VERY secure.
Details are here:
https://www.thebeachcats.…hives/v1-i6/feature1.htm
The only small but very important change is to use stainless screws, not drywall screws.
I spoke with Frank recently about where he sourced the pipe as I was looking for one for another project and found them to be outrageously expensive. He said he vaguely remembered an agricultural supply yard and paid a couple hundred bucks. Finding the pipe at a reasonable cost might be the biggest challenge with this.
At some point the cutting boards and hinges started falling apart and I replaced the access doors with single circles of thick teflon (no hinges). A stainless tang on one side fits into a slot in the pipe, and a standard cam lock on the other side also latches into a slot.
Bill Mattson
Prindle 19 "Gelli Bean"
Prindle 19 "Cat's Pajamas"
I have also been looking to add a 2nd sail box to fit all my stuff. I had been looking at this drainage pipe from Tractor Supply:
https://www.tractorsupply.com/tsc/product/culvert-hdpe-15-in-x-20-ft-hdpe-1520-1330855?cm_mmc=feed-_-GoogleShopping-_-Product-_-1330855&gclid=CjwKCAjw1cX0BRBmEiwAy9tKHg-y3bbNSatWWdUk63OAlAurxXIB7yeHV3z6glT1mzGn6LneMXaKLRoCt3gQAvD_BwE
Note, a quick search of Tractor Supply will show they also have 18" and 24".
You'd want to line that with a plywood "floor" so hardware like the boom and tiller stick slide in an out easily.
Bill Mattson
ropewalkerSam;
No, I take it off for travel. It goes between the trailer front and rear crossbars, where I have some non-skid applied for protection. I've also seen them placed between the front and rear crossbars of the boat itself, with some carpet used for padding.
ropewalkerSam;
mattsonI've been using the same large PVC tube for a sail box for over 35 years. It's on a galvanized trailer that I've exchanged trailers with boats I've purchased over the years. What I like about it is that you can easily use it solo, opening one end and sliding stuff out. And if you replace the cutting boards with thick Teflon panels like I did recently, it can be VERY secure.
Details are here:
The problem is sourcing the large white PVC pipe for this job. It has been replaced with the black corrugated variety from what I have found. The black stuff is less durable, waaay more flexible and hotter. It would work in a pinch but I don't think would make an ideal trailer box.
A friend recently built a box out of galvanized steel roofing and build frames for the roofing from 2" x 2" PVC. Its a slick looking setup.
samc99usA friend recently built a box out of galvanized steel roofing and build frames for the roofing from 2" x 2" PVC. Its a slick looking setup.
Please post photos!
