I've searched for what Hobie 18 Hulls should weigh couldn't find anything. So this winter while I had mine taken apart to wet sand a buff I weighed them. I was somewhat shocked by the range of weight. The lightest hull was 126lb 6oz the heaviest was 136lb 12oz and those 2 hulls were on the same boat ! The other hulls were 134lbs 8 oz and 132lbs even. All weights still had port hatches, bow tangs, rudder gudgeons, drain plugs, shroud pins and trap shock cords left in the hulls.
H14
H18
H18
