Just punched the same boat I sold 15 years ago. This boat is in great shape for being 40+ years old. I am in the process of stripping the boat down and plan to repair some minor hull damage and re-install new items that are worn out. I have spent a lot of time on “The Beach Cats” and am impressed with all the great advice everyone is willing to offer. My first big project is to fix the hull damage where the dolphins striker bar meets the hull. I have included the image and am looking for; 1. Advise on epoxy repair and Gel Coat 2. Identifying the part that is attached to the hull where the damage is. For Item 1 I plan to grind out the damage, sand, prep, epoxy, glass, fill and gelcoat. Does anyone have advice on which brand of Gel Coat is the best. I will be using West System 105 epoxy resin with 205 hardener and investigate which glass and filler to use. I will be looking to roll and tip the area with Gel Coat. I also have some worn Gel Coat spots on the hulls and want to apply a new coat over the entire hull area. I don’t mind sanding and polishing but want to know how much work over spraying as an alternative it will be. I think the mixing, thinning and spraying may be difficult for a novice although I have a compressor. If anyone has a feed on those #2 items for purchase I would appreciate it. Thanks
https://www.thebeachcats.…ictures?g2_itemId=132991
