F18 rear beam match
Hello all,
Is the rear beam for a 2004 nacra F18 the same as a 1994 nacra F18 ?
I assume we are talking a 94 5.5 right? The 2004 f18 will have a D Shaped beam while the 5.5 beam is round.
im talking about a F18. with the D shaped beams. Is there a difference between the D shaped rear beam on a 94 F18 and a 2004 F18 D shaped rear beam?
thanks
In 1994 there were no F18s only Nacra 5.5s which were 18 feet and not similar in any other way.
Hulls different
Rudders different
Rudder castings different
Beams different
Dagger boards different
Tramp different
etc.
Doing some research, the first inter 18 was built in 95 according to sailboat data. This is several years earlier than I was aware of. The inter 18 and the 2004 f18 should have the same or very similar beam extrusions. They are likely possible to swap with each other. I doubt you will find someone online who has actually done that conversion.
Nacra has used that section for every boat after going away from the round tubes. I think the only question/problem you might have is the location of the holes for the beam bolts.
Thank you'all very much.
I have an extra F18 Infusion rear beam if needed.
