Old mast caddie
Anyone happen to have one for sale?
1983 SuperCat 19
Mystere 17
Check Facebook - one is there Hobie Cats, North America. $25
Chuck C
NACRA 500 Mk2
Hobie 21se (sold)
Thanks - I'll check it via my wife's account, as I have a clinical allergy to facebook.
1983 SuperCat 19
Mystere 17
Here you go -
https://www.facebook.com/commerce/listing/551872358818126/?ref=share_attachment
https://www.facebook.com/groups/BeachcatMarketplace\
It's "for a NACRA", but I imagine it'll work or could be modified, perhaps.
Chuck C
NACRA 500 Mk2
Hobie 21se (sold)
Thanks. She seems to be having a bit of a tough time getting to it - might she have to join the group?
- whoops, belay that, she's got it now.
Edited by jonathan162 on Jun 24, 2020 - 03:08 PM.
1983 SuperCat 19
Mystere 17
I'm guessing that "Nacra version" means having the cutout for the traveler track.
1983 SuperCat 19
Mystere 17
Probably...
Chuck C
NACRA 500 Mk2
Hobie 21se (sold)
Jonathan,
Take that piece of sewer pipe you cut off for your sail tube and cut about a 8-10" piece off and use that as the cradle. Notch the bottom to fit the traveler car track. You can use paper or piece of cardboard as a template to get the "right fit", and then transpose to one end of the pipe. Other end just cut bowl shaped for the mast to sit in. Form the part where the mast will sit. When you tie your mast down the cradle will be under it so shouldn't bounce out.
Just an idea.
Good luck
Forrest
I-20 USA-645
Hernando, Florida
"There's not enough rum in the drum"
Love it if it were that simple and I could just get out the jigsaw, but it's not. The original Supercats (of which this is one) have a tramp that wraps completely around the aft crosstube. They did it that way because the first SC was the 20, which had a 12' beam that telescoped down to 8' for trailering, and the traveler runs on a cable (over top of the tramp) instead of a track.
In the later (non-telescoping, trailerable) boats they went to a conventional track on the crossbeam, but I have one of the originals. So whatever I do, it has to clamp around the crosstube and not damage the tramp, just like I think the Mast Caddie will, perhaps with a little padding. Or be something else that I haven't figured out yet.
1983 SuperCat 19
Mystere 17
