No shackle. Tie the pigtails for the jib blocks directly to the clew plate. Install and remove the jib sheet from the blocks/boat each time you rig. This eliminates any chance for the shackle to hangup on the mast/diamond wires, one less part to fail, and the jib sheet gets stored in the sailbox when not being used which extends it life.
Been doing it this way for several years and it is definitely my preferred method.
respectfully prefer to attach the pigtails via a soft shackle
no need to remove the jib lines (ever) unless you want to store. I store under tarp and more so i prefer to save the rigging time - to each their own for sure!
I would love a soft shackle solution, but I need 24" from my jib clew to the jib sheet blocks.
So I would need a monkey fist and loop on each of the three ends. What type of line will be small enough and strong enough to knot in this way? Either the loop or the stopper knot end will have to go through the clew grommet and the jib blocks.
MN3, what kind of knots are those you show?
I suppose I could just tie the clew end and use the soft shackle technique on the jib blocks...
My current line is 3/8" polyester double braid, and I mention this only to reference the strength needed.
-- Sheet In!
Arizona, USA --
The top part is a very small line (4" maybe) eye spliced with 4mm of dynema with an overhand knot on the end. nothing special at all. doesn't even need to be spiced, you could just tie a small loop. the trick is the size of the loop (not so big it wont hold, not so small you can't push the ball through it)
the bottom part is around 1' of 4mm dynema with end splices
the 2 lines are not tied together, simple luggage tagged together
-- Sheet In!
Arizona, USA --
