It’s a Nacra 5.5, one or the forestay bridle anchors failed, cut just under the edge of the hull. I think it was corroded because the surface of the cut was dark.
Anyone has replaced these anchors? I haven’t found a replacement yet, do they sell them? I see some for Hobies but not for Nacra. Any experience, advise, pictures will be appreciated.
It happened on the shore, I was about to jump on the boat to start sailing. Curiously I had the bridle in my hand, I was pushing the boat from it. The mast came down rather slowly with no on close, fortunately. It was a bit hard to remove the mast afterwards, the forestay with the other bridle and bow foil ended up with tension against the opposite shroud. I had to remove the shackle on the mast tang. I’m glad I had pliers on the boat. Had to cut a rope too, glad I had my knife too. ( trying to see the positive side...)
I think I have the incident on the GoPro, will share it later
