Let me start with a disclaimer - all of my aluminum corrosion experience is with aircraft. That includes restoring a 1946 Cessna 140 (lots of corrosion experience there!), plus building airplanes for fun and working at a helicopter company. So if this is not applicable you can dismiss it and my feelings won't be hurt.
The best option would be to replace that part. I realize that can be a challenge, both financially and even to find the parts.
Assuming that was not an option, I'd at least patch the area. I'd have a patch that was bigger than the bad spot, maybe 2X the overall area. The material should be the same type and thickness of the original, which I assume is 6061. You can probably find 6061 at your local metal supply area. Here we have Metal Supermarkets and they are pretty awesome. I did discover that if I call the local office directly the cost is about half as compared to the internet price. Otherwise you could mail order from an aircraft supply company. I would not buy anything from Lowe's Depot.
https://www.aircraftspruc…ges/alumsheet_6061t6.php
The easiest thing would be an external patch. Not sure if that would give you issues with the rigging length. If you cut out the bad area you might be able to put the doubler inside the tube, but that would be a lot harder. If it was my boat I was rescuing I'd go external.
With 6061 you have the option to weld. It may be easier to use Cherry Max rivets. The 1/8" ones, and even the 5/32" ones can be set with a normal hand rivet gun. Note the proper hole size for rivets is a #30.
https://www.aircraftspruc…g/hapages/cherrymax2.php
For corrosion proofing, I'd use an Alodine conversion coating like this. It forms a chemical conversion coating which protects against corrosion, and also makes for great paint adhesion.
https://www.aircraftspruc…e1001.php?clickkey=11999
Having paint in between those parts would be awesome. Some sort of epoxy primer would be the best, or whatever is favored in the boat world. For this area I think anything is better than nothing.
https://www.aircraftspruc…rwhite.php?clickkey=5223
If you want to read more about aircraft aluminum corrosion and repair stuff, AC43.13 is the FAA guide. Page 4-11 for repairs and page 6-25 for corrosion stuff.
https://www.faa.gov/docum…r/AC_43.13-1B_w-chg1.pdf
Good luck!
Bryan in Poplar Grove, IL
Hobie 16, 1977 - died a spectacular death
https://youtu.be/Y7O22bp2MVA
Hobie 16, 1978 - current boat
