[url] function doesn't work
Is this a Safari thing? I can no longer attach a hyperlink.
'82 Super Cat 15
Hull #315
Not running Firefox anymore. The question is about Safari.
'82 Super Cat 15
Hull #315
I was just verifying that the link still works
Edited by MN3 on Jan 12, 2021 - 04:10 PM.
Thanks.
'82 Super Cat 15
Hull #315
gahambyNot running Firefox anymore. The question is about Safari.
Safari is problematic, especially on the iPad I use when out of town. It does not have the “Copy Link As” option for photos.
I have also found that URL results in a link that doesn’t work.
However, after closely looking at the links, (using the EDIT function), I have found a work around for URL
It seems when you embed the link between the brackets, Safari adds a space, usually after the 1st bracket, right before HTTPS. After you post, go to EDIT, you can then delete the added space, & it works...usually. Like so...
https://www.thebeachcats.…c/18319/start/0#pid79906
Edited by Edchris177 on Jan 13, 2021 - 05:07 PM.
Thanks I'll look into that.
'82 Super Cat 15
Hull #315
