The PO switched my tiller connections to a H16 style bolt for unknown reasons. When I got the boat it came with welded proper connectors. I swapped it back yesterday it the rudders are toed out. There is a burr in the aluminum threaded adjuster that will take a 3/4-16 tap to clear, but even with that minimized I won't achieve neutral toe. Are these adjusters aftermarket? Do I need to cut down the cross bar by maybe an inch?
