Square top main for a Dart 18
Hello all,
Can you all suggest a sailmaker for a black square top main for a Dart 18? I live on Kent Island so someone in the Annapolis area would be good.
Kevin
chip from whirl wind is the man!
he is not close - sorry
MN3chip from whirl wind is the man!
Thanks! I just emailed him.
cool - i am very happy with my sails from him
i would request a tube delivery to avoid wrinkles - i wish i did that
Unless you really want a square top I'd suggest a fathead instead. Battens are easier to pack away and it doesn't stick as much in the mast track. Makes a bigger difference than you might think.
iridianUnless you really want a square top I'd suggest a fathead instead. Battens are easier to pack away and it doesn't stick as much in the mast track. Makes a bigger difference than you might think.
Thanks for that info. I have just sent an inquiry to Forward Sailing asking about the fathead.
So, what generally are the differences, pros/cons between a pinhead, fathead and squaretop mainsail?
I've personally only sailed catamarans with squaretops, monohulls with pinheads and there's no comparison between those two.
Chuck C
NACRA 500 Mk2
Hobie 21se (sold)
Recommend Glaser Sails.. the built one for a local Dart 18 sailor and he swears buy it.
John Schwartz
Ventura, CA
JohnESRecommend Glaser Sails.. the built one for a local Dart 18 sailor and he swears buy it.
Olympic builder/ shop should produce incredible sails
i think the main (pun intended) questions are
are you going to race? do you sail in a fleet that you NEED to outsail?
do you want to pay top dollar to a large loft or go with a more economical sail (slower)?
QuoteSo, what generally are the differences, between a pinhead, fathead and squaretop mainsail?
expensive
really expensive
I think i am gonna throw up
