Sharing a couple of modifications I've made to my H20 that you guys may find interesting.
https://i.imgur.com/OOHBpsy.png
First up is my telescoping alu righting pole.
https://i.imgur.com/kVYngxD.jpeg
The materials were about $120, with another $100 to get the brackets and base welded on. I can extend it as far as I want, though at about 11 feet, it's easy to flip the boat solo.
Next is my triangular cargo net. I had this built by Matt over at Sunrise Yachts for $600 + shipping. It can hold about 100 lbs before it starts to drag in the water, and that's without my having even connected the grommets on the rear of the net to the front crossbeam.
https://i.imgur.com/aqQptD3.jpeg
https://i.imgur.com/paV4wuk.jpeg
I have no issues with the weight up front on my miracle, and I've even been able to fly a hull with some weight on the front. Planning to use this to go camping long distances. It's really really great not having everything cluttering up my trampoline.
The next set of modifications I'm considering are a mast rotation dampener connected to my boom to further clear up my trampoline, as well as a motor mount for an electric outboard. (Want the epropulsion spirit evo so badly.)
I intend to wrap the rear crossbeam in carbon fiber around some square tubing so that it is removable. Then I'll cut the mast track free and run bolts through the fiber wrap.
Any thoughts on the motor mount? A little concerned about the integrity of the rear cross beam..
https://i.imgur.com/5kDWDpq.png
