Spi on Prindle 18-2?
Anybody try it? I've got a yard full of beach cats, and the old 18-2 is still competitive with pretty much anything, but the spinnaker on my Inter 17R is like an afterburner. Any advice on what might work well on the 18-2?
Thanks --
George
18-2 is a basically a mini tornado
why wouldn't it work?
i have a spin on my mystere 5.5 - not much difference in the boats
you could use a f18 spin without any issues
or up to tornado / 6.0 spin - that's what i fly
Depends on the year of the 18-2.
There were some hull failures on the early boats that had Surfglass adding an additional bulkhead and stringer to the area forward the main beam. I believe this happen in 1987 or earlier, but I may be wrong.
Another issue could be the small rudders on the 18-2. I have seen this done to a Prindle 18-2 and a 19 - both with the bigger rudders.
Have fun
John Schwartz
Ventura, CA
QuoteThere were some hull failures on the early boats that had Surfglass adding an additional bulkhead and stringer to the area forward the main beam. I believe this happen in 1987 or earlier, but I may be wrong.
I have seen an 18-2 fail at that point - we assumed it was "Oil Canning" \was not aware it was a known issue
what is surfglass? is it S-glass/ S-2 fiberglass. ?
[quote=MN3]
Quote
SurfGlas was Geoff Prindle's original company...
https://forums.sailinganarchy.com/uploads/monthly_2021_07/surfglas.JPG.c17425df703293056de87fa2d2f2a6c3.JPG
https://forums.sailinganarchy.com/uploads/monthly_2021_07/8b04d168b40744e5954b1bc0e856ad64.thumb.jpg.c0dc84b1be53c332bba0aaec96ac933a.jpg
https://www.catsailor.com/hall_fame/GeoffPrindle.html
Edited by JohnES on Jul 27, 2021 - 03:20 PM.
John Schwartz
Ventura, CA
interesting
thanks for the info
I think this is a great idea. I would go with any F18 setup. Pretty much same size and you could get into with replacement parts a plenty.
When I did my P19 years ago, I went with the nacra bail uptop. I just couldnt find it, but shouldnt be too difficult to figure out an attachment up top. I didnt have the MX rudder, but just the standard 18-2/19s at the time.
Regarding the hulls, that is an interesting comment by John regarding hull design. I had not heard of it before either good to know.
Jonathan
Mesa, AZ
Solcat 18 - gone
Prindle 16 - gone
Prindle 19, then with Spin - gone
Prindle 18-2 - gone
Nacra 20 - current
Wanting an F18 with nationals/worlds around the corner...
cloudchsrAnybody try it? I've got a yard full of beach cats, and the old 18-2 is still competitive with pretty much anything, but the spinnaker on my Inter 17R is like an afterburner. Any advice on what might work well on the 18-2?
Thanks --
George
I have a brand new F18 spinnaker (Blue) and a mid pole spinnaker pole and a slightly used red F18 spinnaker if you are interested
