Rudder vibration
I bought a Hobie 16 this year and have had it on the water a couple times. I have found that when I get up to speed, I have a vibration coming from the rudder. What do I need to adjust?
A comment from one of the videos I posted:
rattlenhumFAQ on rudder hum/whale noise: https://www.hobie.com/sup…om/support/tech/hum.html
Here is my rudder noise video:
https://youtu.be/GOX88EIhWDw
Bryan in Poplar Grove, IL
Hobie 16, 1978 - current boat
It's the fat lady singing!
Clinton, Mississippi
Correct me if I'm wrong but I heard it could be caused by your rudders being perfectly aligned which isn't a bad thing. If it annoys you try toeing them in a tiny bit.
Bill Townsend
Sarasota
What type of rudder blades do you have (Lexan, fiberglass, EPO, etc.)? The classic explaination for Hobie rudder hum is turbulence coming off of the trailing edge. The fix is to clean up the trailing edge of the blade.
https://www.hobie.com/for…ewtopic.php?f=18&t=12859
Edited by Dogboy on Aug 20, 2021 - 09:59 AM.
I have the EPO rudders on my H18. They hum quite a bit at speed.
I followed the Hobie “fix”, didn’t do anything, they still hum.
It’s now something I ignore.
We've had success by slightly beveling one side of the trailing edge and giving it an asymmetrical profile. It also helped some with the N20 1st gen. rudder ventilation issues.
I like it.
1978 H18
1983 H18 (some of it)
