Posted: Aug 22, 2021 - 09:38 PM
I second raisehull’s advise, if you attach the line at the mast base only, without a connection further forward, you will see the cat wanting to sail around the anchor, the mast acting as a sail. Simpler but less ideal is to attach it at the forestay base, for one night maybe. Consider limiting mast rotation, you don’t want the mast rotating all the time with the waves, especially on a lake with short waves. I had a shroud failed because of that, after an unexpected little storm at night (Material fatigue after the constant movement). If you have a mast rotator it’s easy to do, not so much otherwise.
