Sailing launch recon - Delavan Lake and Lake Geneva
We took a short ride to check out launch sites at these two lakes in Southern WI. We happened to meet a couple of guys with an H18 and helped them step the mast. Here is a short video of our motorcycle ride and some sailing, shot from shore.
https://youtu.be/0qxspzYd8Do
This is the same trip that I reported here:
https://www.thebeachcats.…c/18529/start/0#pid82183
Bryan in Poplar Grove, IL
Hobie 16, 1978 - current boat
Holy cow,there are more boats in that video than we have on our entire 400 sq mile lake!
Took the N5.0 out in a blow yesterday two up. We were the only boat, of any kind on the water.
Edchris177Holy cow,there are more boats in that video than we have on our entire 400 sq mile lake!
On the bright side, if you have a major failure on that lake, you can just walk back to shore from one boat to another.
We have wetsuits and the cooler/windier weather is coming. That's when we will go to Geneva.
When the cooler weather hits, wear a windbreaker shell overtop your wetsuit. It makes a surprising difference.
Edchris177When the cooler weather hits, wear a windbreaker shell overtop your wetsuit. It makes a surprising difference.
I'll try that. I had found that I was hot at 62F, unless I capsized and then it was comfortable. It was comfortable at 54F, and too cold at 45F, though survivable.
