Video of my H18 and some "improvements" for lake sailing.
https://virtustube-my.sha…r_-v-rTudWWSvVQ?e=PoJUU8
Tim Young
Kentucky
nice mods!
where did you get the pins or did you build them yourself?
Nice! Yes, please- details on the pins, size tubing, etc. That's looking like a must try. Sa-lick.
Chuck C
NACRA 500 Mk2
Hobie 21se (sold)
Cool. Would like to see pictures of your house boat machine shop. Is that in the basement?
Bryan in Poplar Grove, IL
Hobie 16, 1978 - current boat
You should showcase this on JoyriderTV! (Youtube)...unless you already have. This is an interesting setup!
MN3nice mods!
Rudder Pins - Built from scratch -
https://virtustube-my.sha…FVtvqLTtetL7n-Q?e=YWsmC9
The only thing I would do differently is mill 2 slots instead of a long continuous slot. The hole size for the roll pins would need to be enlarged. I started out planning to drill and tap those holes and use SS Shoulder Bolts, but drilling and tapping SS with a tiny tap wasn't working out. So I over-drilled the hole and drove in the roll pins, which work fine. Note that these roll pins are to be driven in while the rudder pin assy. is installed on the boat. Once the roll pins are driven in, the rudder pin assy. cannot be removed, which is what I wanted. If you NEED to remove the rudder pin assy., you can grab the roll pins with vise grips and pinch and pull.
Tim Young
Kentucky
waiex191Cool. Would like to see pictures of your house boat machine shop. Is that in the basement?
Haha... I have some basic tools at the houseboat, but I used the Milling machine where I work for the slot and did the rest at home with basic metalworking tools. The "basement" of the houseboat is full of holding tanks, HVAC, water heater, etc.
Tim Young
Kentucky
QuoteHaha... I have some basic tools at the houseboat, but I used the Milling machine where I work for the slot and did the rest at home with basic metalworking tools. The "basement" of the houseboat is full of holding tanks, HVAC, water heater, etc.
Do you have an online order page? I would like 2 sets please and perhaps 1 spare
thanks! :)
I'd like to see some video of the drill propulsion system in action. That is very clever.
