What you have pictured is not good. Allowing the line to run against the edges of those blocks will end up cutting it. It’s all good until one day you swing out in the wire, & the line breaks.
You go swimming, the boat flips, & you lose the dog bone.
You need the little black chips that go on the line, & run up against the block. They also serve to define where the line stops, & can be adjusted to suit, albeit not as easily as the cleat. Here is the simplest setup.
https://www.thebeachcats.…ictures?g2_itemId=131892
https://www.yumpu.com/en/…manual-sailing-louisiana
I would not setup as in the above post, it’s too much hardware, you don’t need the 2 handle. It also makes the unit too long. It’s a fine line between having the loop what’re you need it, & still have some space for the bungee to keep upward pressure on the dog bone,(note the dog bones give you two points to hook up, you don’t have to always use the bottom one).
If you have 2 people on a 5.7, fixed traps are fine, set them up so the bottom loop has you more horizontal, & the upper loop keeps you higher. This is beneficial when the wind does not warrant both fully out, or in rough water. Being horizontal in rough water means waves tear you off the boat.
However, as Lars points out, adjustable is more versatile. When solo, you need to be able to move to the front beam when going upwind, & for that you need some extra length.
for starting out stay with the KISS principle.
