If you are trying to distribute the hull loading from a single roller, there is an easy way to do it.
I think I got this idea from Dogboy, here on this site.
I only have single rollers on my trailex trailer, the skeg hulled Nacras are fine, but I had concerns about the thinner walled H18.
On the occasional time I move a cat, I roll it onto the trailer, then simply lift each of the rear corners & insert the cradle. The cradle gives far more support than triple rollers would, & cost me 5 cents each to make.
They are just a section cut out of bit of scrap 12” sewer pipe. Screw a couple bits of scrap 2x2 (countersink the heads so they don’t mar the hulls), with one on each side of the roller.
Once you secure the boat, they cannot come out.
When launching, simply lift the corner & remove them.
https://www.thebeachcats.…b0007ce8ffa3cd82c1fdaef1Edited by Edchris177 on Oct 16, 2021 - 10:52 PM.
