Where is the bests place to attach a winch to pull a catamaran?
I was using dolphin striker rod. Is this strong enough? It is used to right the boat all the wind power propels the boat from this rod, but I don't want to bend it at all or change the tension of the v bar. I just replaced it today because it was slightly bent by the pin when lowering the mast too far before removing pin.
The main beam is difficult to pull from because the trampoline get in the way. I need 2 attachment points o pull it straight onto a trailer or up a steep beach.
