Posted: Oct 31, 2021 - 09:29 AM
It is fully normal with a layer of foam in masts, as it is often used for sealing tip and base, do you know yours is completely filled?
Are you sure the mast is leaking, if so you should see where the water leaks out?
Note, the floation from a sealed mast should be in the ballpark of 5kg/m, depending of mast section and wall thickness.So it is fully normal that at least the first meter of the mast is below surface before you right it.
If you want more floatation, get a mast float from Hobie.
Edited by revintage on Oct 31, 2021 - 01:10 PM.
Brgds
Lars
Frankentri 5.8/5.5/Inter20
Aerow trimaran foiler
