Posted: Nov 10, 2021 - 08:40 PM
You didn’t say which cat. I’m assuming,(from the skeg remark), you’re referring to the N5.7
You need to “tip” the boat in order to get the antifreeze at the low point of the hull.
If you do this, be sure to buy RV non toxic liquid, it’s not cool to pour the stuff into the drain or waterway next spring.
Personally, I’d tip your boat way up, drain the hulls, & fu-ged-a-bout-it
I’ve never put anything in either the N5.0 or the N5.7, & we get cold winters in Canada. Never had, or seen a problem.
PM Dave, he has 5.7, in Winnipeg,(Winterpeg), it’s cold enough to freeze the nuts off a steel bridge there, he doesn’t do anything.
Edited by Edchris177 on Nov 10, 2021 - 08:44 PM.
