KL 15.5/Nacra SL16 hulls
Have anyone here heard about this one, it later became SL16? Been offered a pair of cheap hulls, that I aim to build a single hand play cat around. As they are quite a bit away, it would be interesting to know beam diameter and weights.
Got everything else, mast, sails, trampoline material, rudder blades etc. New wider beams are easy to build(the original are only 7.7 ft wide), once you have sourced the correct dimension to fit in the hull pockets.
https://sendbird-schibsted.s3.amazonaws.com/162ABE1D-86E9-4C2A-866A-EF1034525DAF/upload/n/54993caa4ef8479c8bf6aace27f3849e.jpg
https://sendbird-schibsted.s3.amazonaws.com/162ABE1D-86E9-4C2A-866A-EF1034525DAF/upload/n/1b3493af2c2543a28ee935b272021e3c.jpg
https://i3sh32xk.twic.pics/pictures/a/6058ef76d80d80612072b1be/photo-2.jpg?twic=v1/cover=750x750/format=webp/quality=50
Edited by revintage on Nov 17, 2021 - 02:00 PM.
Brgds
Lars
Frankentri 5.8/5.5/Inter20
Aerow trimaran foiler
Looks like makings of a trimaran....
Prindle Fleet 2
TCDYC
Prindle 19 "Mr. Wiggly"
Nacra 5.8 "De ja vu"
Nacra 5.8
Tornadoes (Reg White)
Scott, if I decide to go trough with the deal, you know where to look icon_biggrin . Just two hulls. Old Ashby A-cat main on a cut down Tornado mast and 3m beams. Single handed Frankencat icon_cool .
Edited by revintage on Nov 17, 2021 - 02:02 PM.
I have a friend that is looking to get rid of his Wabbit.... perfect center hull...
Prindle Fleet 2
TCDYC
Nacra 5.8
icon_lol
Brgds
Lars
Have taken a new look in my workshop and found a Nacra 5.5 mast to chop up for two 10ft beams. The beam pockets are quite narrow so the beams will be positioned with the luff track upwards. With the track cut away, the section is 105x76mm.
http://revintage.se/mastsection.jpg
Striker rod from M16 316 threaded rod, Nacra style, with 5mm DUX Dyneema instead of striker band. An 1.75" Delrin ball fits perfectly in the almost antique Tornado mast base I found.
Will try out the cut down alu Tornado mast w/o spreaders to begin with, as it most likely is to stiff for the Slingsby main. Nothing wrong with a fuller sail, as this one is 50kg heavier with a lot more RM. I am also open for trying it boomless with a stiffer lower batten.
http://revintage.se/drawing.png
Just found out the SL16, with exactly the same Yves Loday designed hulls as KL15.5, where made by Nacra for the US market:
http://www.jimyoungsailing.com/b_sl16.htm
Edited by revintage on Nov 23, 2021 - 11:19 AM.
Brgds
Lars
revintageHave taken a new look in my workshop and found a Nacra 5.5 mast to chop up for two 10ft beams. The beam pockets are quite narrow so the beams will be positioned with the luff track upwards. With the track cut away, the section is 105x76mm.
http://www.jimyoungsailing.com/b_sl16.htmEdited by revintage on Nov 23, 2021 - 11:19 AM.
What about moving the forestay hound up a bit, add short spreaders with pre-bend? Could give you some bend control... or make the diamond tension adjustable? We did that on a 5.2 in the 90's. Had the diamond adjustable from the wire...
Prindle Fleet 2
TCDYC
Nacra 5.8
Hi Scott,
My idea is to avoid more outlay than what I pay for the hulls. Hound heights around 280cm from the top is std for the A-cat, for the Tornado the rules say ca 220cm. Will absolutely take your point of view in account before I drill. If I later decide to use the F18 main I will have to add diamonds for better bend control, together with higher hounds. The lower hounds will be made with a T-terminal like the A-class cats and will not be in the way. So nothing fancy at first icon_wink .
https://image.jimcdn.com/app/cms/image/transf/dimension=120x1024:format=jpg/path/seef9e1de51f24309/image/i29018c9a939fea4f/version/1308211096/image.jpg
Edited by revintage on Nov 23, 2021 - 04:30 PM.
Brgds
Lars
revintageHi Scott,
https://image.jimcdn.com/app/cms/image/transf/dimension=120x1024:format=jpg/path/seef9e1de51f24309/image/i29018c9a939fea4f/version/1308211096/image.jpgEdited by revintage on Nov 23, 2021 - 04:30 PM.
I get the idea of keeping cost down. The most money I have in FrankenKitty is the name (besides the new sails). I'm trying to negotiate acquiring a broken Flying Phantom mast for it... icon_cool
Prindle Fleet 2
TCDYC
Nacra 5.8
QuoteI'm trying to negotiate acquiring a broken Flying Phantom mast for it...
Nice mast but quite heavy. I actually built a short mast for my foiler project from a trashed FP mast. It was in really bad shape, broken between upper diamond and hounds, but I managed to get the 8m mast I needed out of it.
https://scontent-arn2-1.xx.fbcdn.net/v/t1.6435-9/95606456_10219148261511009_524507247343042560_n.jpg?_nc_cat=109&ccb=1-5&_nc_sid=b9115d&_nc_ohc=pl8ABDdxed0AX8A33tX&_nc_oc=AQk1MujgSn0qjL6EBme5yRpr5eT1fGc5ODZJWWQ_Sex9Z5e5S7sGfcrCUir4dc4xgZk&tn=zqplvoM8R_mA4TDG&_nc_ht=scontent-arn2-1.xx&oh=3001359cb1a6be07cd5caa1af989d5ae&oe=61C3021D
https://scontent-arn2-1.xx.fbcdn.net/v/t1.6435-9/100903164_10219425803609388_9216547561454698496_n.jpg?_nc_cat=102&ccb=1-5&_nc_sid=b9115d&_nc_ohc=KSwy9Jr7TwkAX-EV6DR&_nc_ht=scontent-arn2-1.xx&oh=eea3f4fd5150b6ab5644e3b8bde75ac1&oe=61C41343
https://scontent-arn2-1.xx.fbcdn.net/v/t1.6435-9/95477914_10219161922292520_6164036367710945280_n.jpg?_nc_cat=106&ccb=1-5&_nc_sid=b9115d&_nc_ohc=lwlzxRgyscQAX-8Xa9U&_nc_ht=scontent-arn2-1.xx&oh=2183794584ae377e9462b5b5a418ceb8&oe=61C594A2
https://scontent-arn2-1.xx.fbcdn.net/v/t1.6435-9/101223024_10219425806209453_8784636720931930112_n.jpg?_nc_cat=101&ccb=1-5&_nc_sid=b9115d&_nc_ohc=DqQEMaHbaD4AX9B76D7&tn=zqplvoM8R_mA4TDG&_nc_ht=scontent-arn2-1.xx&oh=cf6deefb38d83e56ada65945cf745f76&oe=61C485D3
http://revintage.se/completetube.jpg
https://scontent-arn2-1.xx.fbcdn.net/v/t1.6435-9/106085066_10219699555013002_7794506384011987137_n.jpg?_nc_cat=102&ccb=1-5&_nc_sid=b9115d&_nc_ohc=84oaM_1PCyEAX_conW1&_nc_ht=scontent-arn2-1.xx&oh=b02d6bb7f0b37a23b36b5fe0b3e7ff3b&oe=61C4B22C
https://scontent-arn2-1.xx.fbcdn.net/v/t1.6435-9/106422733_10219715793738960_1127503732668286461_n.jpg?_nc_cat=102&ccb=1-5&_nc_sid=b9115d&_nc_ohc=_D303cCQipYAX8VNvoj&tn=zqplvoM8R_mA4TDG&_nc_ht=scontent-arn2-1.xx&oh=4275dc3afe4428f7d6464b3b4b47f302&oe=61C2B09E
Edited by revintage on Nov 24, 2021 - 04:02 PM.
Brgds
Lars
QuoteNice mast but quite heavy.
It's more than I need, but the budget is within range. I don't have a problem with raising the Prindle mast, it would be just one more "boat in the puzzle".
Prindle Fleet 2
TCDYC
Nacra 5.8
Had to dump up the project, as the hulls where in bad shape and heavy icon_frown . Think even my 5.5 hulls are lighter, will move that one to the lake house instead and keep the 5.8 Frankencat here.
Edited by revintage on Dec 10, 2021 - 08:45 AM.
Brgds
Lars
