Have seen this on a badly corroded 18SQ beams with the front beam patched. Returned them and made new beams from 100x2mm. Made a good deal as I got two 5.8 hulls in exchange.
EDIT: Finally found the image of what was hidden beneath the patch on the 18SQ beam I received
If the holes are so big that the distance tube falls out make a new that is 2x1,6mm longer. Add patches top and bottom made from the other beam. I guess 7x7cm cm is enough. A 4.8mm blind rivet in each corner should do. Then add larger and thicker 9/16" washers than before, that you round to follow the beam diameter. Lower the mast and the job will be done in half an hour, then sail on for the rest of the season. Don´t forget the beam pre-bend, I don´t know what the 5.5 instructions say, but I would go för 10-12mm.
Edited by revintage on Feb 21, 2022 - 10:03 AM.
Brgds
Lars
Frankentri 5.8/5.5/Inter20
Aerow trimaran foiler
