Prindle chainplate question
Has anyone ever replaced chain plates on there cat?
“Prindle 18-2” in particular. I am recoreing the decks and Planning on installing new chain plates while I have it opened up.
Any words of advice, would be much appreciated.
are they really worn out?
1978 H18
1983 H18 (some of it)
If it ain't broke, don't fix it!
Brgds
Lars
Frankentri 5.8/5.5/Inter20
Aerow trimaran foiler
Thanks for your input fellas !
I will do a good visual inspection when I open up the deck, and if all looks good I will close the deck back up with ultra light core cell foam and fiberglass.
I went through the trouble to remove both bow decks when 1 bow tang failed
also broke through a (second) bulkhead to replace both side-tangs when 1 chainplate/tang failed
it may not be a bad idea to replace when you have access as preventative maintenance - esp if the cat was used in salt water
Edited by MN3 on Apr 05, 2022 - 08:01 PM.
On a boat this old? It would probably be smart preventive maintenance. You will have to get some fabbed up though
Captain Chris Holley
Fulshear, TX
'87 Prindle 19 "¡Hijole!"
'74 sunfish "1fish"
Thanks guys! I’m gonna install new ones for the long haul!
