I am trying to set up a used Mystere 6.0. I am new so I'm not using the spinnaker pole and instead was going to connect the forestay directly to the bridle wires/bridle plate. However, there isn't a stay adjuster so I'm confused on how it all comes together. (This images is the same setup as mine https://static.shoplights…es/003868937/h1802b1.jpg)
1) I don't have the top section of wire above the swivel. Do I need to have this remade?
2) With out a stay adjuster, is it the pulley + jib halyard wire that will adjust the rig tension?
3) Where does everything attach and secure and in what order? My initial thought, from top to bottom, was forestay > furler > bridle plate > bridle wires. But where does the tack of the jib secure? In videos I've seen this is attached to the lowest hole on the stay adjuster.
