Hull cleaning, glue removal
Hi!
Last time I renewed the non-skid strips on my hulls they didn’t adhere well, I was too lazy to properly clean the hull surface after removing the old ones. Now I decided to put eva foam on a larger area, got some with 3M adhesive. The question is how should I clean the glue from the strips that I removed? Thanks!
Naptha works well on adhesive residue. I'd check to make sure it does nothing bad to your hulls though.
Bryan in Poplar Grove, IL
Hobie 16, 1978 - current boat
AndinistaHi!
Goo Be Gone works very well for adhesive. You can also use acetone.
Prindle Fleet 2
TCDYC
Prindle 19 "Mr. Wiggly"
Nacra 5.8 "De ja vu"
Nacra 5.8
Tornadoes (Reg White)
