Prindle 16 Hull concern
Is this a concern? Is hull failing (see wavy pattern on inside of hull)
https://photos.app.goo.gl/KGg8ujNttdDJ5Vr46
Dave R.
Grand Haven, MI
'84 Prindle 16
I’m not terribly familiar with the details of the Prindle hull construction, but when Hobie hulls get wavy like that, it’s generally a sign that there is substantial delamination going on. At the very least, I would press firmly on the hull all around that area. If it’s soft, you have a problem and I would not recommend sailing the boat until the hull is repaired or replaced. Soft spots on the inside of the hull near the front crossbar can potentially lead to the bow snapping off due to bridle wire loads.
When you press up against it does it feel spongie or firm?
John Schwartz
Ventura, CA
I acquired a P-18 because it had that look while sailing. Tap on the hull with a small hammer (or hard thing) and listen for hollow sounds.
Prindle Fleet 2
TCDYC
Prindle 19 "Mr. Wiggly"
Nacra 5.8 "De ja vu"
Nacra 5.8
Tornadoes (Reg White)
